rimasidd
Feb 05, 2022Tutor
RBR850/RBS850 WiFi slow on a 1GIG fiber (getting 90Mbs up/down)
I have att 1 gig fiber ( 1 RBR router ) - (4 satellites) 6500 SQ ft house satellites are 25-30 ft apart on second floor < Router ( which acts as bridge) also on second floor ( hard wired to ATT) ...
Mikey94025
Feb 05, 2022Hero
Try starting with the diagnostic steps outlined in the community FAQ: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944. The results will isolate where your speed drop is occurring, then we can focus improvement steps for that point.
- rimasiddFeb 05, 2022Tutor
Thanks i did all that .
hardwired into att arris - 750 download, 930 upload
hardwired into RBR Router - 94 ( upload 'download)
reconfigured everything so that att Arris is set up a a bridge , RBR set up as router with pass through. Issue is hardwired right out of RBR speed is extremely low
- Mikey94025Feb 05, 2022Hero
rimasidd wrote:Thanks i did all that .
Thanks, now we know to look at the RBR speed drop and can factor out wireless for now. So you have bridged your modem and wired download speed is 94 Mbps vs. 750 Mbps when removing the RBR? That is surprising.
Do you recall what default settings you changed on your Orbi? Make sure you have not enabled Armor, Circle, Speed Test, Access Controls and Traffic Meter.
As a last resort, how do you feel about factory reseting the Orbi and then seeing if the speeds recover?
- rimasiddFeb 05, 2022TutorI don’t think resetting the Orbi is an issue, the only changes I made were on the att box .. rbr was already in AP mode
