Jroach
Jun 06, 2023Luminary
rbr850/rbs850 won't release device, duplicate device
I have a few sonos speakers. The sonsos ONE will disconnects and won't reconnect. Sonos support points to Orbi/network as the problem. In my "Attached Devices" using the browser page, I see (2)...
- Jun 06, 2023
Try setting up a IP address reservation for each device.
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF one of the devices. Go in and set the reservation. Apply the change and have the RBR set it. Then turn OFF the 1st devices then turn ON the 2nd devices and do same thing again for 2nd device.
bullm00n
Jun 06, 2023Virtuoso
Sonos can get "moody", I have found. For a time, I had all mine on reserved IPs, but haven't done it with my latest 960/850 flip-flop saga. I don't think it is necessary but can help with network management if you have a lot of devices connected. If you are on a PC, check out a free app called "Advanced IP Scanner" - super handy for sorting out what is going on with connected devices over and above what Orbi or Sonos tells you.
What I have found I have had to do in the past with Sonos is that when it gets wonky, I power down all the Sonos devices for a few minutes while rebooting the network. After the network is back up and no Sonos, then one by one, bring all the Sonos devices back up. This doesn't happen often, but it does happen. Other symptoms are: Sonos device doesn't show up in App, but a network scan shows it online. Sonos device shows up in app but cannot be controlled. Sonos devices randomly show up or disappear from the app.
Good luck.
- JroachJun 06, 2023Luminary
bullm00n I have had the same experience as well. It's rough when you are having people over and your tending to your speakers:)
Also doesn't make it an easier when Orbi reports the wrong devices...one day its a camera then its the washer. Per @furrye38 I've assigned more devices to the address reservations in groups so I can easily see if something has been mislabeled.
- bullm00nJun 06, 2023Virtuoso
Jroach wrote:bullm00n I have had the same experience as well. It's rough when you are having people over and your tending to your speakers:)
Check out "Advanced IP Scanner". It's much better at showing what devices are on the network than Orbi. Its free and invaluable.
Thanks, good advice. I use LanScan (mac product) but I suspect it does a similar thing. I forgot I had it until I got knee deep into resolving Orbi's "Attached Device" mislabeling.
