Jroach
Jun 06, 2023Luminary
rbr850/rbs850 won't release device, duplicate device
I have a few sonos speakers. The sonsos ONE will disconnects and won't reconnect. Sonos support points to Orbi/network as the problem. In my "Attached Devices" using the browser page, I see (2)...
- Jun 06, 2023
Try setting up a IP address reservation for each device.
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF one of the devices. Go in and set the reservation. Apply the change and have the RBR set it. Then turn OFF the 1st devices then turn ON the 2nd devices and do same thing again for 2nd device.
Jroach
bullm00n I have had the same experience as well. It's rough when you are having people over and your tending to your speakers:)
Also doesn't make it an easier when Orbi reports the wrong devices...one day its a camera then its the washer. Per @furrye38 I've assigned more devices to the address reservations in groups so I can easily see if something has been mislabeled.
bullm00n
Jun 06, 2023Virtuoso
Jroach wrote:bullm00n I have had the same experience as well. It's rough when you are having people over and your tending to your speakers:)
Check out "Advanced IP Scanner". It's much better at showing what devices are on the network than Orbi. Its free and invaluable.
