Jroach
Jun 06, 2023Luminary
rbr850/rbs850 won't release device, duplicate device
I have a few sonos speakers. The sonsos ONE will disconnects and won't reconnect. Sonos support points to Orbi/network as the problem. In my "Attached Devices" using the browser page, I see (2)...
- Jun 06, 2023
Try setting up a IP address reservation for each device.
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF one of the devices. Go in and set the reservation. Apply the change and have the RBR set it. Then turn OFF the 1st devices then turn ON the 2nd devices and do same thing again for 2nd device.
CrimpOn
Jun 06, 2023Guru - Experienced User
Jroach wrote:
I have a few Sonos speakers. The Sonos ONE will disconnects and won't reconnect.
In my "Attached Devices" using the browser page, I see (2) Sonos One speakers with the same IP and different mac addresses. On the Sonos app (IOS) there are (2) as well, one attached to the satellite, the other to the router.
I believe every Sonos speaker has the Ethernet MAC address printed on the case. Does one MAC address match the case of the Sonos One and the other match the MAC address of one of the other Sonos speakers?
Are any of the Sonos speakers connected to the system with a cable (Ethernet)?
