kildren
Sep 03, 2024Aspirant
RBR850/RBS850/RBS850 issues
Is there anyway to force the backhaul through another Satellite all the time? I have a Router in the basement, wired to a Satellite on the top floor in a window facing my Shop with Line of Site to a...
Sep 03, 2024Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
kildren
House is 3000' at the bottom of the hill, 300' from the house to the Shop window, shop is metal, then 100' of Cat6 to a satellite in the back yard on a 20' pole. The last satellite can not see anything without the wire to the shop satellite.
Firmware V7.2.6.31_5.0.24
There is a good 200' of dirt between the router and the shop... no idea why it keeps switching to it.
- FURRYe38Sep 03, 2024Guru - Experienced User
Try lowering the power to 25% and see.
What is the distances between the RBR and the 1st RBS closest to the house?
Has a power cycle OFF for 1 minute then back ON or factory reset been performed since v.31 was applied?
Ya thats quite a ways in between.
- kildrenSep 03, 2024Aspirant
Well I moved the router to the 3rd floor , and the satellite to the basement. Everything is showing good strength now and so far has stayed stable. I can connect to all 3 satellites via their IPs really fast now, before it was slow to respond, figured that was how it updated, now I see I was wrong..
Good thing I ran 2 CAT6 up to the 3rd floor...
- FURRYe38Sep 04, 2024Guru - Experienced User
Check back with us in 3 days to let us know how it does.
Ya, basements are not good places for the main RBR.
Hope it keeps working good for you...
