KMDonlon
Jun 10, 2020Virtuoso
RBR852 - App started showing an additional satellite??
I am reposting this here as I have had zero input in the Orbi app forum, wondering if anyone else has noticed this..... This is a recent issue, the Orbi app is showing an additional satellite that ...
- Jun 27, 2020Finally solved the mystery satellite issue in my Orbi app. Had time to do a complete factory reset and set everything back up from scratch. I believe my back up config file imported something corrupt and caused the issue of the "satellite-2" showing that was never there.
Chuck_M
Jun 10, 2020Mentor
Can you characterize what devices are connected (wired or wireless) to the real satellite?
What firmware is on the satellite and on the router? (be specific)
I had an issue in the past with a Sonos Boost which was actually backfeeding my satellite causing something like this.
KMDonlon
Everything is wireless, nothing connected via Ethernet to either the router or satellite. I am running the same devices that I have always run, thermostats, 4 cameras, video doorbell, Chromecasts, tablets, phones, etc. Nothing new has been added wirelessly since this mystery satellite appears. Also, the extra satellite icon appears to be an older Orbi system if you look at the photo attached.
Also, running latest firmware v. 3.2.15.25.
I believe it is a bug in either the app or latest RBR852 firmware.
