KMDonlon
Jun 10, 2020Virtuoso
RBR852 - App started showing an additional satellite??
I am reposting this here as I have had zero input in the Orbi app forum, wondering if anyone else has noticed this..... This is a recent issue, the Orbi app is showing an additional satellite that ...
- Jun 27, 2020Finally solved the mystery satellite issue in my Orbi app. Had time to do a complete factory reset and set everything back up from scratch. I believe my back up config file imported something corrupt and caused the issue of the "satellite-2" showing that was never there.
Jun 28, 2020Guru - Experienced User
What browser do you use to manage and save the config file?
KMDonlon
Jun 28, 2020Virtuoso
All done on my Android mobile using mobile Chrome.
- FURRYe38Jun 28, 2020Guru - Experienced User
You may want to use a wire/wireless PC and a different brower. IE11, FireFox or Opera to save off backup configurations. Possible the mobile device and or Chrome could be introducing problems.
