Meadster
Feb 11, 2025Tutor
RBR853 - Samsung Galaxy S23 Ultra / S25 Ultra - doesn't like to play
Hi All, So, I have had my RBR853 system since 2022 and it works pretty good and is used in AP mode connected to my service provider's router at the moment, that's a EE Smart Hub Plus (wifi6) with a ...
Feb 23, 2025Guru - Experienced User
Any progress on this?
New FW is out:
Please update and check. May need a facory reset and setup from scratch to ensure a good take on the new FW and see if all works better for you.
