slane01
Mar 23, 2022Guide
RBR853 and MyQ Integrated Camera
I currently have Liftmaster / Chamberlain Smart Garage Door Openers with Integrated Cameras. These connect to the MyQ App for the smart device control and for the camera/video viewing. I have th...
CrimpOn
Mar 23, 2022Guru - Experienced User
slane01 wrote:
How do I verify that the TCP/UDP ports are open and available? I do not have any port triggering/forwarding setup, nor do I have any ports blocked.
This is the issue. Chamberlain says that ports must be forwarded through the router to the camera and you have not done so.
By default, all ports are "blocked" unless the customer specifically uses the web interface to unblock them. This is done on the Orbi web interface, Advanced Tab, Security Menu. All ports are blocked because you did not forward any.
I confess to being surprised by this requirement. My Wyze and Reolink cameras do not require any ports to be forwarded in order to view camera recordings or live video. When a port is forwarded, it can forward only to a single IP address on the LAN. That means only one MyQ camera can exist. ( maybe no customer ever purchases more than a single MyQ camera? not even one customer... ever!)
- ComputerGuy1984Mar 24, 2022Initiate
Usually, Universal Plug N Play (UPNP) is enabled by default on most routers, which might explain why most devices work fine out of the box, but if the device does not utilize the UPNP protocol to tell the router which ports it needs to open, or if you have turned it off, that might explain why you have the issue. My myQ garage door opener has not had an issue, but not sure if that is the same as with the camera model that you mentioned.
- slane01Mar 24, 2022Guide
I have UPNP enabled and have also tried disabling it with no success. I did create a custom port forwarding rule with the ports that Chamberlain had requested. I have no issue connecting the Orbi to the MyQ opener. It opens and closes the door just fine. Unfortunately it cannot communicate to the integrated cameras.
I spent a total of 1.5 hrs today on the phone with 2 seperate Chamberlain techs trying to work thru the issue, but have not had any luck.
The 2nd Chamberlain tech is suspecting it is the camera itself. However, it was escalated to a 3rd level of support which I am supposed to get tomorrow. Chamberlain did email me requesting my shipping address, so it does seem they are going to send a new camera.
Unfortunately, since I had another new opener sitting in a box, I opted to open it up and swap the cameras from the 2nd new opener into the first installed opener.
The 2nd camera also does not connect, which is leading me to believe it isnt a camera issue but rather a configuration issue.
Does the Port forwarding rule look correct to open up the ports. Chamberlain requested ports 4444, 9122, 4101-4104 and 5101-5104 to be enabled for TCP/UDP send & receive.
Any guidance would be appreciated.
Thanks
Steve
- Mikey94025Mar 25, 2022Hero
It seems the Chamberlain Smart Garage Opener's integrated camera is different than the MyQ Smart Garage Camera that is available separately, but both are setup using the MyQ app. I own the MyQ camera and it did not require port forwarding (which is not something customers would know how to do, so surprising if required by the Chamberlain integrated camera... It's also extra difficult if the customer has Double NAT).
I don't know if it will help, but try setting CTS/RTS Threshold to 2347 because that sometimes improves compatibility with 2.4Ghz devices (you've already tried disabling AX mode, the other common tactic):
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
If that doesn't help, confirm that your security setting is WPA2. What else have you changed from the Orbi defaults?
