slane01
Mar 23, 2022Guide
RBR853 and MyQ Integrated Camera
I currently have Liftmaster / Chamberlain Smart Garage Door Openers with Integrated Cameras. These connect to the MyQ App for the smart device control and for the camera/video viewing. I have th...
Mar 25, 2022Guru - Experienced User
I just noticed this you posted:
- Ensure you have 802.11n (802.11 b/g/n) enabled. myQ cameras do not support 802.11ac
Seems a bit sketchy to not support wireless ac or AX.
Got an old router sitting around? If so, you could connect that one in access point mode and limit it to wireless n. Maybe that'd work.
Then you could set your orbi back to being able to use its full AX setup.
slane01
Mar 25, 2022Guide
I may give that a shot as I do have an old router.. I had disabled AX features on the orbi 2.4ghz frequency, but didn't have any success.
- slane01Mar 26, 2022Guide
Well I think I am getting closer to understanding why my cameras won't connect. The ports required by the mfg are not open.
They need to have ports 4444, 9122, 4101-4104 and 5101-5104 open. I have setup port forwarding rules several different ways. However, the port forward does not seem to work.
I have also tried forwarding just a single port such as 9122 with no luck either. When I run a port scan on one of the devices IP Address it only shows (2) Open ports, none of which are in the Port Forward list.
Any suggestions?
I appreciate the help.
The snip below is the port forward setup for all of the required ports for the cameras to work apparently.
Thanks
Steve - Mikey94025Mar 27, 2022Hero
This is quite the puzzle. Your port forwarding setup seems correct per the instructions you posted earlier (from this Chamberlain support page). Let's confirm your camera model. In particular, verify it is not like this one: Smart Garage Camera. I ask because I have this camera connected to my LiftMaster opener and no port forwarding was required.
If it is a different camera model, we can perhaps find other references to confirm what is necessary and which ports to forward. I have so far not been able to find any other web references to Chamberlain camera and the ports mentioned.
- slane01Mar 27, 2022GuideUnfortunately it is not like the MyQ Smart Garage camera, it is the integrated camera inside the opener.
The label on the side of the camera says GDOCam1 or 2 depending on opener.
The device shows up in the Attached Devices list as Ampak Technology.
It literally makes no sense to me as connectivity to the openers work just fine. - ComputerGuy1984Mar 27, 2022InitiateSome internet providers block all ports on their end until you call them. My cousin just had this issue with his ISP, for a game server he was trying to set up.
- slane01Mar 27, 2022GuideI'll definitely have to give that a shot. It definitely sounds plausible.
I am a little doubtful that the problem is port forwarding. That support link doesn't mention port forwarding and may only be describing ports that the camera device opens to the outside network and with bidirectional traffic, i.e., the router should not block outgoing requests on those ports from internal devices.
Otherwise, if port forwarding were required and internet hosts actually connect *into* your home network via those ports then a household could never have more than one of those devices. This is just a camera and you are not setting up a minecraft or other game server where multiple clients need to connect to your device.
Your camera is blinking green. Have you already reset and tried everything again per these instructions? Your camera device is connected via the main network, not a guest or other network, right? Do you have any security, Armor, etc. settings enabled?
Is this PDF the instructions for your camera and does it look like this, i.e., a cylinder thing that inserts and attaches to the bottom of your garage opener? What does your MyQ app say about the camera? For example does it recognize the camera so you added it to your account and it shows up in the app, just no video available?
- slane01Mar 27, 2022GuideIt is basically that same integrated camera, just a little newer style opener.
I have spent 2 hours on the phone with Chamberlain as well. Done multiple camera resets and re-adds.
It connects and is added to my MyQ account, it just shows offline. The LED on camera is blinking green, which indicates that it is connected to my router, but is unable to connect to the MyQ Internet Server.
However the MyQ door function works just fine.
I am waiting for the callback on the 3rd round of Chamberlain support as well.
Chamberlain did have me remove the integrated camera and try to re add it as a standalone camera, but that didn't work.
I have Nest Cameras all over the rest of my house and those work just fine.
It really shouldn't be that hard to configure lol. - cdenneenJun 01, 2022Aspirant
My camera worked for over 1 year without issue and have NOT changed anything in my setup (ISP, modem, router, wifi, etc) now mine blinks green and is offline as well. I do not have a NetGear like you but have the same issue which leads me to believe they changed something upstream on the My Q server that these cameras are connecting to.
- slane01Jun 01, 2022GuideThats interesting and I think your probably right.
I have spent countless hours trying to get my damn cameras to work.
I finally just gave up on it and told the MyQ tech support I'd never recommend these to anyone.
I was just happy that the MyQ function for opening and closing the door worked as it should.
That all occurred several months ago.
These things have just flashed blue and green forever.
However,
Last week I had went on vacation. When I returned a week later I noticed the indicator lights were now solid green on both my openers.
Out of curiosity, I pulled up the MyQ app and could now see both cameras and they were functioning as they should.
I didn't do a damn thing different. They just started working on there own, which leads me to believe it is definitely a MyQ issue.
I'm not sure if they will stay working, but they have now been online for a week which is shocking. - cdenneenJun 01, 2022AspirantMy issue is without the camera the Key Delivery for Amazon which is beyond frustrating
