Meadster
Feb 11, 2025Tutor
RBR853 Satellite Replacement Power Plug....
Ok, so I managed to snap the little lug that secures the socket pins to the power brick. Thinking this was an easy fix by contacting Netgear for a replacement only to be told nope tough titty you nee...
CrimpOn
Feb 11, 2025Guru - Experienced User
I would try SuperGlue.
What happens when you contact the manufacturer of your television or computer and ask for the same part?
- plemansFeb 12, 2025Guru - Experienced User
I'd agree with CrimpOn superglue/epoxy might be your best option and better than the 3rd party power supplies. It looks like your connections will be fine, its just the retainer clip. A bit of JB weld epoxy would probably be stronger than the original clip anyway.
