Beantowm111
Apr 04, 2023Apprentice
RBR860 - Satellites not showing as connected
I have an RBR860 with 3 satellites that were working great. Today I noticed that in my app the satellites all appear as offline but are still transmitting fine. I went into the web interface for each ...
- Apr 05, 2023A second reboot of router solved problem. I guess maybe there was some kind handshake issue. Thank you for the response!
Beantowm111
Apr 05, 2023Apprentice
Apr 05, 2023Guru - Experienced User
