GregS_from_MI
Sep 11, 2025Apprentice
RBR860 intermittent disconnects
I have had this Router plus 1 satellite since March 2023. It is connected to Hitron EN2251 modem from Spectrum. The router and modem are plugged directly into the wall plug. Both sit in the open and ...
GregS_from_MI
Here are my answers in Bold.
Does the RBR or RBS front LEDs turn ON PINK or blink white when this happens? Always turns white and flashing. Not fast.
What Firmware version is currently loaded? Firmware Version V7.2.7.15_5.1.16 I have Auto Firmware Update On.
What is the size of your home? Sq Ft? It's a ranch at 1400 sq ft overall
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected. The satellite is in the garage and is 40+ feet away.
Does this happen with the RBS turned OFF? No, I haven't done that. Really didn't expect that would be a problem since the satellite was located a distance from the router.
Does this happen with both wireless and wired devices? Yes happens to both. My office has the modem and router in the same room. My desktop is wired to the router. But I see the disconnect on both wired and wireless at the same time it occurs.
I use channel 1 and 40 on my Orbi systems. I'm currently on 11 and 48. There are only 4 channels available on the 5G.
Any Wifi Neighbors near by? If so, how many? I live in a small rural neighborhood. One on either side, plus across the street. No one behind us. I know this is not very scientific, but I have a WiFi Analyzer, freebie of the internet, I did a Channel Graph screenshot of 2G and 5G bands. Again I'm on channel 11 and 48.
Has a factory reset and setup from scratch been performed since last FW update? I am running on factory default right now. The default SSID is ORBI18.
Mikey94025
Sep 12, 2025Hero
This is very interesting. Since your wired devices are also disconnected then we can narrow focus to WAN or satellite internet service rather than wireless things for the moment (like which channel, iPhone-specific settings or issues). I assume that all your wired and wireless devices disconnected when the problem occurs, right?
Are any of your wired devices that get disconnected wired to the main router? If yes we can also ignore satellites for the moment. I'd want to know if your orbilogin.com says it is disconnected from the Spectrum modem too.
- GregS_from_MISep 12, 2025Apprentice
You asked: I assume that all your wired and wireless devices disconnected when the problem occurs, right?
Yes, both wired and wireless devices get disconnected when the problem occurs.
Yes, my wired device, desktop computer is wired to the router. The router is about 5 feet from the desktop.
To my understanding, I don't think I can connect to the login.com screen if there is no connection. I'll try on the next occurrence.
- Mikey94025Sep 12, 2025Hero
You can still connect to your Orbi's website (orbilogin.com) even if you do not have Internet access but still have local LAN access. If your disconnect means you don't have LAN access (DHCP IP address) then that is a very different, and unusual, issue.
If your disconnect is no Internet access, then the next time it occurs on your desktop wired to the main Orbi router try going to http://orbilogin.com/ the next time it occurs. See what it shows for Internet Status on that page. It usually says STATUS:GOOD and if not, then we need to look at something between your Hitron EN2251 modem from Spectrum and the Orbi. Everything else doesn't matter.
