rvirani's avatar
rvirani
Tutor
Nov 23, 2022
RBR960 device limits on IoT?
Are there any concurrent device limits on the IoT network on the new RBR960? The spec sheet states the mesh system can handle 200 devices, but I am having challenges connecting all of my IoT devices to the router simultaneously. That 200 figure is also not broken down by main network vs guest network vs IoT network.
I have the router and two satellites, which should theoretically cover 9,000 sq ft, placed strategically around my roughly 6,000 sq ft home. My home has about 150-175 connected devices at any given time with about 30 of those being wired devices. I am specifically having trouble connecting 94 recessed lights on the perimeter of my home simultaneously to the IoT network. I haven't tried connecting these to the main network yet, as that would be a pretty heavy lift to update the wi-fi settings on all of these devices. I have the IoT network broadcasting in 2.4ghz only as the majority of these IoT devices are 2.4ghz only. The 94 recessed lights I am having trouble with are definitely 2.4ghz only.
I was thinking about putting my older RB850 mesh system (router with 4 satellites) into AP mode and connecting them to my new RB960 system for added coverage, but I am not sure that the wi-fi signal extending outside is the problem. On the 5ghz and my iPhone is getting 175mbps down at about 60 feet outside of my house.
Any suggestions would be appreciated!
  • CrimpOn's avatar
    CrimpOn
    Page 155 of the User Manual says this:
    My guess is that 127 is a hard limit and has nothing to do with which SSID the device connects to (primary, guest, IoT). Nor would adding another WiFi system in Access Point (AP) mode help with that limit.
    The key may depend on the app used to control this brand of lights.
    With an 850 product on hand, I would experiment with connecting the 850 (as a router):
    • Reduce the power level of the 5G radio to 25% (the lowest possible) to reduce interference with the new 960 system.
    • Set the 2.4G WiFi channel to avoid interference with the 960 system.
    • Connect a smart phone to the 850.
    • Connect one bulb to the 850 system.
    Then, see if the smart phone app will control that bulb when the phone is on the 960 system.
    I have a similar situation where I have KASA smart plugs.  Most are connected to the primary WiFi network, and four are connected to a different router.  No matter which network the phone is connected to, the app can control all of the switches.  (Which makes sense because the app allows control of products installed in different physical locations when the phone is not at physically at any of them.)
    94 is a substantial number.  One wonders if the products based on Zigbee or other standards can handle this many?
    • rvirani's avatar
      rvirani
      Tutor
      Thank you for your response. How did you arrive at the 127 number? The reason I decided to upgrade to the RB960 system was less about the new 6ghz band and more about the 200 device limit. If the router cannot handle 200 devices or anywhere close to that, then that’s pretty disappointing.
      • CrimpOn's avatar
        CrimpOn
        I just opened the manual and found page 133.  Don't know where the 200 number can be found.  Sounds a lot like Marketing Speak to me (rather than engineering).
        Since none of us are Netgear employees, we have zero knowledge of what's actually going on inside Netgear.
