rvirani
Nov 23, 2022Tutor
RBR960 device limits on IoT?
Are there any concurrent device limits on the IoT network on the new RBR960? The spec sheet states the mesh system can handle 200 devices, but I am having challenges connecting all of my IoT devices ...
rvirani
Nov 24, 2022Tutor
The 94 lights are on 4 automated switches that are zigbee and controlled by my xfinity home hub/app. I was able to get all but 2 connected concurrently last night by providing an address reservation for each device, but still no luck on connecting all of them at once. I may try to discontinue the IoT network all together and see if I can connect everything concurrently to the router. fingers crossed.
I tried a three eero mesh network and a three deco mesh network (both the newest 6E systems but without a dedicated IoT network) and both got all of the devices connected after about 30 minutes. And those systems are 25% of the cost of the Orbi 963. I do want to stick with the Orbi system since it has been a wonderful system for me for so many years (this is my third mesh system), but it is really frustrating that it isn't working!
CrimpOn
Nov 24, 2022Guru - Experienced User
This is part of the reason I have been reluctant to plunge headlong into the "Internet of Things" (which technology to commit to?)
Zigbee apparently has a theoretical capacity of 65,000 devices. So, the Zigbee switches can turn an entire string of lights on and off, but cannot do anything to the bulbs directly (such as change color. If the lights are all ordinary white bulbs, there seems to be no reason to access them directly.). The bulbs support WiFi, but not Zigbee, so it requires 94 IP addresses to be able to change their color (and could also be used to turn them on/off and thus make the Zigbee switches redundant).
I get dizzy just thinking about it.
Sorry not to be more help. The turkey dinner was fine, but the pie has sent my blood sugar through the roof!
- MusrmgrFeb 23, 2023InitiateI had the RBK850 and it could not handle my 140 devices. (75 Kasa light switches, 20 ring cameras, and other various IoT devices.
I upgraded to the 960 this week and have the same disconnect issues.
I tried running only 2.4 and then both 2.4 and 5 on the IoT but that didn’t help.
What settings should I have for the IoT network and the network as a whole to get my IOT devices to stop dropping, slow, etc… - rizwanFeb 23, 2023Initiate
Correct, the 960 series cannot handle 200 devices or at least not the majority over wi-fi as it is currently marketed to be able to do. After days upon days on the chat and phone with Netgear tech support, they stopped responding to any troubleshooting efforts. I went ahead and returned all of the Netgear products I had purchased and switched to the Ubiquiti DreamMachine SE. Best decision I have ever made. Each AP can handle 300+ devices depending on the AP model. You can mix and match. Right now I regularly have 160 devices online at night when all of the lightbulbs turn on. The customization and fine tuning options on the radio power and radio bands are far superior to any Netgear product.
I believe the issue with the Netgear products is that each radio band can have a maximum of 32 devices that can be connected simultaneously and even then, the router itself cannot handle all of the traffic. I believe that to be the issue, but I cannot be sure because Netgear totally gave up on helping me.
My advice - if you have that many devices, look into a small-biz setup like the Ubiquiti Unify product line. Message me if you want to know more details about my setup. Good luck!
- Mikey94025Feb 23, 2023Hero
rizwan wrote:I believe the issue with the Netgear products is that each radio band can have a maximum of 32 devices that can be connected simultaneously and even then, the router itself cannot handle all of the traffic.
This has not been my experience with my household of devices. I run 70+ devices, mostly 2.4Ghz but including a fair number of 5Ghz phones/laptops/Nest cameras, on my Orbi 9-series and previously used the 8-series product with these same devices.
What settings should I have for the IoT network and the network as a whole to get my IOT devices to stop dropping, slow, etc…Have you turned off AX mode for 2.4Ghz? That helps with compatibility for older 2.4Ghz wireless devices which cannot benefit from AX anyway. I also used to set CTS/RTS Threshold to 2347 for the same reasons, but the latest firmware doesn't make that available anymore.
Your devices disconnecting (dropping) or having connectivity issues (slow) may be due to other reasons than having a lot of them. Do you have too many satellites for your home coverage (if yes, try experimenting with just one satellite and if that helps try reducing power)?
