rvirani
Nov 23, 2022Tutor
RBR960 device limits on IoT?
Are there any concurrent device limits on the IoT network on the new RBR960? The spec sheet states the mesh system can handle 200 devices, but I am having challenges connecting all of my IoT devices ...
Musrmgr
Feb 23, 2023Initiate
I had the RBK850 and it could not handle my 140 devices. (75 Kasa light switches, 20 ring cameras, and other various IoT devices.
I upgraded to the 960 this week and have the same disconnect issues.
I tried running only 2.4 and then both 2.4 and 5 on the IoT but that didn’t help.
What settings should I have for the IoT network and the network as a whole to get my IOT devices to stop dropping, slow, etc…
rizwan
Correct, the 960 series cannot handle 200 devices or at least not the majority over wi-fi as it is currently marketed to be able to do. After days upon days on the chat and phone with Netgear tech support, they stopped responding to any troubleshooting efforts. I went ahead and returned all of the Netgear products I had purchased and switched to the Ubiquiti DreamMachine SE. Best decision I have ever made. Each AP can handle 300+ devices depending on the AP model. You can mix and match. Right now I regularly have 160 devices online at night when all of the lightbulbs turn on. The customization and fine tuning options on the radio power and radio bands are far superior to any Netgear product.
I believe the issue with the Netgear products is that each radio band can have a maximum of 32 devices that can be connected simultaneously and even then, the router itself cannot handle all of the traffic. I believe that to be the issue, but I cannot be sure because Netgear totally gave up on helping me.
My advice - if you have that many devices, look into a small-biz setup like the Ubiquiti Unify product line. Message me if you want to know more details about my setup. Good luck!
- Mikey94025Feb 23, 2023Hero
rizwan wrote:I believe the issue with the Netgear products is that each radio band can have a maximum of 32 devices that can be connected simultaneously and even then, the router itself cannot handle all of the traffic.
This has not been my experience with my household of devices. I run 70+ devices, mostly 2.4Ghz but including a fair number of 5Ghz phones/laptops/Nest cameras, on my Orbi 9-series and previously used the 8-series product with these same devices.
