Jente
Jun 13, 2023Tutor
RBRE 960 blocks sunpanel and alarm internet
Dear all, We just bought the orbi RBRE960 system and i connected 3 sattelites. Evetything seemex to work fine up untill the moment i connected my solarpanels with homebattery and my outdoor cameras...
- Jun 22, 2023
Thanks for all the help.
The company of the converter for my solarpanels cantacted me and told me it’s is a problem in the converter itself. So there was no problem at all with my orbi system.
Jente
Jun 17, 2023Tutor
First and all thanks for the quick respond.
To be clear i have other devices connected wireless and through cable and they all seem to work fine, just these 2 wont connect to the internet.
I'll try to answer your questions as best as possible.
Firmware version: V6.3.7.10_3.3.3
I live in Belgium and i use Telenet and i have their latest model modem.
The cable is fine i tried it on an other device.
I have one router and 3 sattelites
My home is about 3100sq ft
IoT SSID network is disabled so they are not connected to this network.
They are both connected through wire.
Hope this helps in finding a solution.
Jun 17, 2023Guru - Experienced User
Might contact the Mfr of these sun panels to see if they can help out here as well.
- JenteJun 22, 2023Tutor
