JHRucker
Aug 29, 2022Aspirant
RBRE 960 Wifi clients constantly disconnect/reconnect
I think I'm seeing the same thing with my RBSE960 router and the two satellites. I live on a farm, no outside WiFi issues, but the satellites just drop clients randomly, maybe half a dozen times a da...
Aug 30, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
