Meh_n3tg3ar
Jan 03, 2025Aspirant
RBRE 960
Since November, speed measured by the Orbi app shows just 250Mbps download and 2Gbps upload. Previously, download was always in the 1.7Gbps range. Thought ISP was the issue, but they said all customer...
Jan 03, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What brand and model device are you using to speed test with?
Meh_n3tg3ar
firmware is 7.2.6.31 Yes, Cat 6 cable is connecting the router to the ont. I can’t get any info off the isp modem. special tools needed to open it and get info
- FURRYe38Jan 03, 2025Guru - Experienced User
Has this been working ok before v.31 was applied?
- Meh_n3tg3arJan 03, 2025AspirantYes, .31 was installed quite a while ago.
Do you know if the ISP modem is a Cable modem or Fiber ONT?
Who is your ISP?
And are you speed testing with a wired PC at the RBR alone with out the RBS being online?
