Meh_n3tg3ar
Jan 03, 2025Aspirant
RBRE 960
Since November, speed measured by the Orbi app shows just 250Mbps download and 2Gbps upload. Previously, download was always in the 1.7Gbps range. Thought ISP was the issue, but they said all customer...
Meh_n3tg3ar
Jan 06, 2025Aspirant
see photo. i gave 2gb service, but the desktop only has a 1 gb card. same server gonetspeed. web version, ~1gb/1gb. applet, 250mb/1gb. Same results on all servers. Remove Orbi and run ethernet directly to the desktop, 1gb/1gb on both website and applet. Speed from Orbi ios app, 250mb/1.8gb
CrimpOn
Jan 06, 2025Guru - Experienced User
Internet search turns up other examples of the Ookla Speed Test app producing lower results than the Ookla web site:
https://www.reddit.com/r/techsupport/comments/rtzdui/different_download_speeds_when_using_the/
In this specific instance, however, getting identical results when connecting directly to the ISP seems inconsistent with those descriptions.
If this is the same version of the Windows 'app', "I got nothin"
