Dlasch's avatar
Dlasch
Follower
Apr 22, 2025
RBRE950 220v
Can I bring my orbi purchase in USA to Italy and buy a converter to work with 220v?
  • FURRYe38's avatar
    If the converter outputs 110 volts, it should work.
    You'll need to check on the specs of the converter to be sure.
    Might check on the power adapter that comes with the RBRE, sometimes they are dual power supporting.
