Psychopasta
Jul 20, 2022Aspirant
RBRE950 Firmware Update problem
Hi, I have an RBRE950 router with two satellites, all working fine except that the check for firmware update fails. On Advanced/Administration/Firmware update it gives the Status as 'Service Unreach...
- Aug 22, 2022
Hi Furry,
I'll try that next time I can power cycle without the family moaning. It's purely a web server issue, all devices are actually on the new subnet so its not causing any operational problems.
I'm still curious why it won't find the firmware service but my guess is it'll be cured by the next formware update anyway. No need to stress out on this, I'll just keep my eyes open for firmware updates for the 950 series.
- Mark
Jul 20, 2022Guru - Experienced User
There is nothing newer currently.
What browser are you using?
Can you capture a screen shot of what your seeing?
- PsychopastaJul 20, 2022Aspirant
Hi Furry,
It's a standard Cox box:
Panoramic Wifi Gateway
Brand: TECHNICOLOR
Model: CGM4140COMI'm using Microsoft Edge. The screenshot is attached.
- Mark
I should add, I cannot update via the app either.
- CrimpOnJul 20, 2022Guru - Experienced User
It is probably useful to ask if this is the only time that goofy error message has appeared?
i.e. Always before it came back with "No new firmware"?
- FURRYe38Jul 20, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
Psychopasta wrote:
Hi Furry,
Brand: TECHNICOLOR
- Mark
Hi again Furry,
I've always seen 'double NAT' as a benefit, not a problem. I've used it for ages in all my previous Wi-Fi installations. What problems does it cause?
- Mark
