Psychopasta
Jul 20, 2022Aspirant
RBRE950 Firmware Update problem
Hi, I have an RBRE950 router with two satellites, all working fine except that the check for firmware update fails. On Advanced/Administration/Firmware update it gives the Status as 'Service Unreach...
- Aug 22, 2022
Hi Furry,
I'll try that next time I can power cycle without the family moaning. It's purely a web server issue, all devices are actually on the new subnet so its not causing any operational problems.
I'm still curious why it won't find the firmware service but my guess is it'll be cured by the next formware update anyway. No need to stress out on this, I'll just keep my eyes open for firmware updates for the 950 series.
- Mark
Aug 22, 2022Guru - Experienced User
You might power OFF the Orbi system for 1 minute or longer then back ON. Should clear out any old addresses from the routers page.
Psychopasta
Aug 22, 2022Aspirant
Hi Furry,
- Mark
