Riversight
Jan 06, 2023Follower
RBRE960 - 10 Gbit/s IPS but only 500-700 mbit/s over wifi. Normal?
The advertisement for wifi 6e says I should get a way higher speed. Did they get me with misleading advertisement, or is something wrong with my system?
Jan 06, 2023Guru - Experienced User
What device are you testing on and how far from the router/satellite are you?
Its usually the device you test with that is the bottle neck. Plus speeds for 5ghz/6ghz (especially 6ghz) drop of quickly with distance/obstructions
