vanshvisuals
May 09, 2022Tutor
RBRE960 - Airprint does not works
HI - I am unable to print using Airprint to either of my two connected printers (Canon & HP) using Mac/iPhone/iPad. No changes to the printer (airprint enabled). They used to work with my previous Orbi. This started to happen when I changed my Orbi to the new RBRE960. Same SSID/password as the previous one.
Has anyone seen this problem? Any advice/suggestions?
Be sure FW is up to date on the printer.
Set up a IP address reservation for the printer on the RBR.
Review this:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax/page/2
Contact the printers mfr for additional help and information regarding there printer products.
Thanks for a quick reply. Unfortunately, same issues with both the printers. I can't even find them
Latest firmware: Check
Reserved IP: Check
Manufacturers: It was working fine with the previous Orbi, so it cannot be the printers. Two separate printers (HP & Canon), both having the issue
