picataggio
Aug 02, 2023Aspirant
RBRE960 - blocks a site : HTTPS://secure.oldbridge.com/Tax/SitePages/login.aspx
Firmware Version V6.3.7.10_3.3.3 GUI Language Version V3.0.2.20_2.1.30.3 Operation Mode Router I have to pay my property taxes for a house I own in NJ. The first site I ha...
Aug 03, 2023Guru - Experienced User
I notice that your first URL is malformed.
There is the following characters after this URL> %2C/
I can get to both corrected URLs fine here.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- picataggioAug 03, 2023Aspirant
Cable Modem is from Spectrum (formerly Charter Communications)
Model E31T2V1
DOCSIS 3.1 eMTA
(i am sure they OEM it)
As I mentioned, I can get to the first site - oldbridge.com
The problem is getting to the 2nd site, whether I use the button on the first site or I just COPY LINK and manually bring up a new tab and paste it in.
I am using the ethernet cable that came with the ORBI.
I also had an extra Router sitting around and tried that and I had no issues getting to the site with that Router plugged into the Cable Modem.
It is only the Orbi I am having the issue with.
- CrimpOnAug 03, 2023Guru - Experienced User
I also discovered that the "comma symbol" {,} on the end of the posted URL caused my browser to report "no such link".
Removing the comma made it come up.
Both of the other links worked from that home page.
Might be worth checking again Sometimes things get "stuck" in browsers.
