NegatedVoid
Mar 17, 2022Aspirant
RBRE960 - IoT network doesn't show up
Hey, I've setup a Orbi RBRE960 with two satellites. It updated to the latest firmware (V6.0.3.85_3.1.15), and I enabled the "IoT network" on a unique SSID. It's set to "WPA2-Personal" and "2.4Ghz an...
- Mar 22, 2022
A factory reset seems to have sorted it out, and the IoT network is broadcasting now (with the exact same settings as before).
Kindof a huge pain to have to factory reset it and reconfigure everything, but at least it's working.
Mar 17, 2022Guru - Experienced User
What is the SSID name you input?
Try using the default SSID name?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
