NegatedVoid
Mar 17, 2022Aspirant
RBRE960 - IoT network doesn't show up
Hey, I've setup a Orbi RBRE960 with two satellites. It updated to the latest firmware (V6.0.3.85_3.1.15), and I enabled the "IoT network" on a unique SSID. It's set to "WPA2-Personal" and "2.4Ghz an...
- Mar 22, 2022
A factory reset seems to have sorted it out, and the IoT network is broadcasting now (with the exact same settings as before).
Kindof a huge pain to have to factory reset it and reconfigure everything, but at least it's working.
CrimpOn
Mar 17, 2022Guru - Experienced User
NegatedVoid wrote:
However, none of my devices see that SSID. I've restarted the router via the Orbi app as well.
Perhaps it would help to know what kind of IoT devices these are.
99% of my smart plug, etc. etc. have no option to change WiFi networks. They have to be factory reset and set up from scratch again.
