NegatedVoid
Mar 17, 2022Aspirant
RBRE960 - IoT network doesn't show up
Hey, I've setup a Orbi RBRE960 with two satellites. It updated to the latest firmware (V6.0.3.85_3.1.15), and I enabled the "IoT network" on a unique SSID. It's set to "WPA2-Personal" and "2.4Ghz an...
- Mar 22, 2022
A factory reset seems to have sorted it out, and the IoT network is broadcasting now (with the exact same settings as before).
Kindof a huge pain to have to factory reset it and reconfigure everything, but at least it's working.
NegatedVoid
Mar 22, 2022Aspirant
Mar 22, 2022Guru - Experienced User
Glad you got it working. Yes sometime a reset works well. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed. đ
Enjoy. đĄ
- NegatedVoidMar 22, 2022Aspirant
thanks for the tip! marked as solved.
