A3ch
Sep 21, 2022Follower
RBRE960 - My IoT password is all of a sudden not working
I have over 60 devices connected to my IoT network and in the process of connecting a new device it wants me to be on the network that I want the device to communicate on. When I attempt to enter th...
Sep 21, 2022Guru - Experienced User
Try changing the IoT password to something else. Apply the change. See if you can connect to it with a mobile device. If you can, then change it back to what you had been using. Apply the change. Use a PC and web browser to make this change on the RBRs web page.
Do you have the separate 6Ghz radio enabled?
