guitarman555
Oct 15, 2022Tutor
RBRE960 - wireless connection from bedroom pc to orbi goes way down in speed
I’m having troubles getting my bedroom PC to connect to the orbi’s with consistently high speed. I use a 6E wireless card. The TP Link AXE5400 When everything is working right, the card pulls down ...
- Oct 18, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
guitarman555
Oct 18, 2022Tutor
Right now my PC is working again normally. Yesterday morning, I couldn't get on the internet at all, even after rebooting modem/router/PC
I did that several times with no luck.
Then I went to the Orbi app, and deleted my PC and rebooted it, and since then everything has been fine. Something I'll keep in mind in the future if this happens again!
Oct 18, 2022Guru - Experienced User
Enjoy. 📡
