guitarman555
Oct 15, 2022Tutor
RBRE960 - wireless connection from bedroom pc to orbi goes way down in speed
I’m having troubles getting my bedroom PC to connect to the orbi’s with consistently high speed. I use a 6E wireless card. The TP Link AXE5400 When everything is working right, the card pulls down ...
- Oct 18, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
guitarman555
Nov 01, 2022Tutor
I thought about that, is it my wi fi card? But after seeing the same symptoms appear on my Downstaris PC (wired with ethernet) and my phone, I figured my wi fi card (in the bedroom pc) was fine. If that was the only device giving me that trouble, then yes, I'd figure it was time to try a different wi fi card.
I did a factory reset and the problems were still there until they weren't. Sounds crazy, but that's what's happening. Right now, knock on wood, everything's working fine. I'll reply to the thread if the symptoms reappear though.
Sounds good about the firmware update. I'll get that going tomorrow morning. Thanks for the heads up!!
Nov 01, 2022Guru - Experienced User
