vanshvisuals
Jun 13, 2022Tutor
RBRE960 : 400 Bad Request while adding Address Reservation
Need urgent help. I've a new RBRE960 system with 4 satellites. Internet is working fine. I am trying to add an address reservation in Advanced > Setup > LAN Setup. I add the device ( a printer) and...
- Jun 14, 2022
NO NO. I have 50+ devices connected, but I am only trying to add 2 address to reservations.
Anyways I just reset the entire system and it works magically now. Save firmware as earlier. No idea what was the problem.
Mikey94025
Jun 13, 2022Hero
vanshvisuals wrote:I am trying to add an address reservation in Advanced > Setup > LAN Setup. I add the device ( a printer) and then when I click apply, it gives me the "400 Bad Request" error. I have tried multiple browsers (in incognito mode) and multiple computers (Mac and Windows) but same error.
I have not had similar errors setting up DHCP address reservations with my RBR960. Are you saying this happens with any device, any IP, or is it specific to this one printer device? Does it have a weird Device Name string? Do you have a really long list of reserved addresses (there used to be a bug once you got to ~70 something). A screenshot of the Address Reservation page before you hit Add may be helpful.
For example, on LAN Setup page where it lists the current devices and their local IPs I usually:
- Press the Add button at the bottom of the page, below the Address Reservation list. This takes you to an Address Reservation page that only shows a list of devices within an Address Reservation Table list.
- Now select one of the current devices, to autofill the form at the very bottom of the page (IP Address, MAC Address, Device Name).
- Now press the Add button at the top of the page to add the new Address Reservation. Sometimes it takes a while for the web page to return (if you have a lot of reserved addresses).
vanshvisuals
Jun 13, 2022Tutor
Thanks. It gives me the same error with any device I select from the list. The name is simple (Canon). And I follow the same steps as you mentioned.
1. Click 'Add' at the bottom of the screen on LAN Setup page.
2. Select the device that I need to add, from the list that comes up (attached devices). Once selected, click the Add button at the top of the screen.
3. It comes to the previous screen (LAN Setup) with the new devices added up.
4. Click on the Apply button at the top of the screen. Thats when it gives the error. (If I dont do this step, the reservation will be lost when the router is rebooted).
- CrimpOnJun 13, 2022Guru - Experienced User
Now would be a good time to save a copy of the router configuration.
Doing a factory reset is almost trivial when there is a copy of the configuration to reload.
- vanshvisualsJun 13, 2022Tutor
OK So I've backed up the config. Can you please help how to reset it and use the backed up config file? Never done that. Thanks.
II don't know if a factory reset is the 'next step'. In my own experience, it is the last option when everything else has failed.
As I recall, this is the procedure:
- Do the Factory Reset (I use a paperclip to press the button hidden behind that tiny 'Reset' hole and wait until the Power LED turns amber and begins to flash).
- Open a web browser on a computer (I like to use one connected with an Ethernet cable. WiFi will work as well, but that adds the step of connecting the computer to WiFi and reconnecting it again when the router reboots).
- Enter the IP of the router (usually 192.168.1.1) or http://orbilogin.net
- Enter the default admin credentials ("admin", "password")
- Go through the configuration being careful to:
- Ignore instructions to get the Orbi app
- Do not enter the previous WiFi name (SSID), because that will cause every device that is looking for WiFi to connect and get some random IP that you don't want them to have.
- Ignore anything to do with Armor or Parental controls (there is usually a line in tiny print at the bottom of the page saying "I don't want this"
- Ignore instructions about Registering the product with Netgear
- Very soon a screen will come up with choices to
- Restore a saved configuration, or
- Enter a configuration manually
- Browse to the location where the configuration is saved. Select the file. Apply.
- After the configuration is loaded, the router will reboot (two minutes) and when it comes back up, the entire configuration is as it was before. When all devices see the WiFi SSID appear, they will all connect and get the correct IP addresses.
I can do this in under 10 minutes..
