vanshvisuals
Jun 13, 2022Tutor
RBRE960 : 400 Bad Request while adding Address Reservation
Need urgent help. I've a new RBRE960 system with 4 satellites. Internet is working fine. I am trying to add an address reservation in Advanced > Setup > LAN Setup. I add the device ( a printer) and...
- Jun 14, 2022
NO NO. I have 50+ devices connected, but I am only trying to add 2 address to reservations.
Anyways I just reset the entire system and it works magically now. Save firmware as earlier. No idea what was the problem.
vanshvisuals
Jun 13, 2022Tutor
Thanks. It gives me the same error with any device I select from the list. The name is simple (Canon). And I follow the same steps as you mentioned.
1. Click 'Add' at the bottom of the screen on LAN Setup page.
2. Select the device that I need to add, from the list that comes up (attached devices). Once selected, click the Add button at the top of the screen.
3. It comes to the previous screen (LAN Setup) with the new devices added up.
4. Click on the Apply button at the top of the screen. Thats when it gives the error. (If I dont do this step, the reservation will be lost when the router is rebooted).
CrimpOn
Jun 13, 2022Guru - Experienced User
Now would be a good time to save a copy of the router configuration.
Doing a factory reset is almost trivial when there is a copy of the configuration to reload.
- vanshvisualsJun 13, 2022Tutor
OK So I've backed up the config. Can you please help how to reset it and use the backed up config file? Never done that. Thanks.
- CrimpOnJun 13, 2022Guru - Experienced User
II don't know if a factory reset is the 'next step'. In my own experience, it is the last option when everything else has failed.
As I recall, this is the procedure:
- Do the Factory Reset (I use a paperclip to press the button hidden behind that tiny 'Reset' hole and wait until the Power LED turns amber and begins to flash).
- Open a web browser on a computer (I like to use one connected with an Ethernet cable. WiFi will work as well, but that adds the step of connecting the computer to WiFi and reconnecting it again when the router reboots).
- Enter the IP of the router (usually 192.168.1.1) or http://orbilogin.net
- Enter the default admin credentials ("admin", "password")
- Go through the configuration being careful to:
- Ignore instructions to get the Orbi app
- Do not enter the previous WiFi name (SSID), because that will cause every device that is looking for WiFi to connect and get some random IP that you don't want them to have.
- Ignore anything to do with Armor or Parental controls (there is usually a line in tiny print at the bottom of the page saying "I don't want this"
- Ignore instructions about Registering the product with Netgear
- Very soon a screen will come up with choices to
- Restore a saved configuration, or
- Enter a configuration manually
- Browse to the location where the configuration is saved. Select the file. Apply.
- After the configuration is loaded, the router will reboot (two minutes) and when it comes back up, the entire configuration is as it was before. When all devices see the WiFi SSID appear, they will all connect and get the correct IP addresses.
I can do this in under 10 minutes..
- TC_in_MontanaJun 14, 2022Virtuoso
I have had no issues with assigning Address Reservations on my 960, but I don't have quite as many as you do.
I'm wondering if you hit some limitation on the number of reserved addresses. 49 seems to be an odd number, but you never know how things may be coded.
Can you try deleting one of the other reserved addresses, hitting apply, and then try to add the printer's reserved address again and see if it takes it. If so, try and add the one that worked properly and that you deleted, and see if it gives you the error again. If it is constantly giving you the error on the 50th entry - then I think it may be a limitation issue or a coding issue and not something specific to that address or device.
If it is a limitation/coding issue - it's something that will need to be addressed with engineers to fix/change code. For a device this powerful to have a limitation of 49 reserved addresses seems pretty strange - but I've seen stranger things.
- vanshvisualsJun 14, 2022Tutor
