MeshedUp
Oct 30, 2022Tutor
RBRE960 & RBSE960 firmware update issues
My RBRE960 and two RBSE960 satellites are running firmware version 6.0.3.85. Noting that new firmware -- 6.3.7.5 -- has been released for these units, I attempted to upgrade and ran into the followin...
- Oct 30, 2022
Thanks for the tip. It worked as you described. In order to complete all three updates, I used the Orbi app to find the satellites' IP numbers and logged into each individually. One satellite took the update software on the first pass; the other satellite had to be re-booted before it would accept the new firmware upload. The RBRE960 manual update worked fine also.
MeshedUp
Oct 30, 2022Tutor
Oct 30, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
