Mjh2157
Jan 27, 2023Tutor
RBRE960 / RBSE960 Firmware Version v6.3.7.10 Yes, random wifi drop outs.
Yes, random wifi drop outs. My wife is on wifi off a satelite that has a backhaul and her wifi drops on her work laptop and S10+ phone regularly.
Jan 27, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor, SPC, IoT and Separate 6Ghz SSID networks enabled?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- Mjh2157Jan 27, 2023Tutor
-6.3.7.10 on router and 3 satelites.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?-Altice GR140DG in bridge mode
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.- using certified Cat6a. Cat6a from ONT to 960 router 10G port. Cat6a form 960 router 2.5g port to Netgear 4300 switch. CAT6A from 3 ports on M4300 at 2.5g to each of 3 satelites 2.5g port. Everything was working perfectly with the last two previous firmwares.
5,500 sq ft
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.- one satelite on cat6a in basement from m4300 switch on first floor about 75' from router
- one satelite on cat6a on 2nd floor from m4300 switch on first floor about 40' from router
- one satelite on cat6a on 3rd floor from m4300 switch on first floor about 75' from router
AUTO everything
Any Wifi Neighbors near by? If so, how many?- i see one other distant neighbors ssid sometimes with 1 signal bar, I live in the woods.
- none of those items are enabled. screenshot:
- yes, attempted several times
Turn on computers and rest of network.-attempted several times. I besides my wife's thinkpad and s10 plus having random drops I have also had wifi issues with my nest thermostat all of sudden that I never had with a previous firmware. The nest thermostat have been working for about a year now until this firmware came out.
- FURRYe38Jan 28, 2023Guru - Experienced User
Is FW same on RBS as whats loaded on the RBR?
How was the FW updated on the system?
Try setting manual channel 1 on 2.4Ghz and 40 channel on 5Ghz.
Also try turning down the power output of the RBRs wifi radios from 100% to 50%. Under Advanced Tab/Advanced Settings/Wireless Settings.
- Mjh2157Jan 28, 2023Tutor
- yes
- manually, satelites first then router then reset all then reload saved config.
- ok, done
- ok, done
