Mjh2157
Jan 27, 2023Tutor
RBRE960 / RBSE960 Firmware Version v6.3.7.10 Yes, random wifi drop outs.
Yes, random wifi drop outs. My wife is on wifi off a satelite that has a backhaul and her wifi drops on her work laptop and S10+ phone regularly.
Mjh2157
Jan 28, 2023Tutor
Is FW same on RBS as whats loaded on the RBR?
- yes
How was the FW updated on the system?
- manually, satelites first then router then reset all then reload saved config.
Try setting manual channel 1 on 2.4Ghz and 40 channel on 5Ghz.
- ok, done
Also try turning down the power output of the RBRs wifi radios from 100% to 50%. Under Advanced Tab/Advanced Settings/Wireless Settings.
- ok, done
Jan 29, 2023Guru - Experienced User
See how it goes. I see you reloaded a saved config, seen it where older saved configs can cause problem with newer versions of FW. If you see a continueed problem, i'd FR and setup from scratch with out loading a saved config file.
Give it 3 days for now...
