orbiqueries
Jan 17, 2025Aspirant
RBRE960 / RBSE960 Satellites, Ethernet Backhaul, Mutliple Switches
I have a single RBRE960 with four RBSE960 satellites (hardwired). None show up in the Orbi app as being connected to each other. I expect that this is because there are multiple switches (but the ...
orbiqueries
Jan 26, 2025Aspirant
Thank-you for asking - sorry - I missed the alerts that there had been replies.
1.
What FW is loaded on the RBR and RBS? - All of them are on 7.2.6.31
What brand and mode# are these switches? - they're a mix of Netgear, Linksys, and D-Link.
How are the RBS connected to these switches? using 1Gb ports or the 2.5Gb port? - 2.5gb.
What CAT# lan cable are you using? - Cat-8 certified cables.
Which port on the RBR are you using? The 1Gb or 2.5Gb port? I've been flicking between trying the 10, 2.5, and 1gb.
All of the Orbis connect via switches.
Jan 27, 2025Guru - Experienced User
1.
Been posts about v.31 not working well for users.
What region are you located?
What are the model #'s of these switches?
Different branded switches may not work well for ethernet connected RBS. I've learned over the years to keep with one brand of switch for use in between the RBR and RBS. I've tested NG, HP and D-Link. Non managed switches with out green ethernet features are best.
CAT# STP is recommended for use with RBS connected on there 2.5Gb ports.
If you don't have any multi gig supporting switches, then use the 1Gb ports on the RBR and RBS to connect them. No need to use the 2.5 or 10Gb ports when you can't fully and seamlessly support those speeds between the RBR and RBS.
