F_V
Apr 04, 2023Luminary
RBRE960 1GB Ports Power Cycling?
Hey all, just set up the RBRE960 router and two RBSE960 satellites. Initial stability was a little touch and go, but it seems to have calmed down and now it's pretty stable. I have my Orbi set up i...
- Apr 26, 2023
Well, I was finally able to test this again. Disconnected all cables and then connected the Orbi 1GB router ports to my Netgear GS108v4 unmanaged switch. Tried all Orbi 1GB router ports and all 8 unmanaged switch ports, and I cannot duplicate the strange behavior from before. Now the two devices connect at 1GB speed and stay connected with the activity lights blinking constantly as expected. Not sure why it's different now, but I'm glad that it's now acting the way it's supposed to. Thank you for testing this setup, that took some effort and it's much appreciated.
F_V
Apr 12, 2023Luminary
Not sure this will help, but I run my Orbi in AP Mode and if I plug any of the 3 LAN 1GB LAN ports on the back of the Orbi into a switch it just power cycles over and over and never holds a consistent connection.
