gumpgump
Oct 20, 2023Guide
RBRE960 (7.2.6.21) and 2.4ghz-only IoT and Sonos Playbar Gen 1
I have a RBRE960 on a single network that has several Sonos speakers. The issue I am having is that the Sonos Playbar (GEN 1) is 2.4ghz only -- so the controller doesn't see it well. I tried enab...
gumpgump
Oct 20, 2023Guide
By "controller" I am referring to the iOS app -- for some reason, there's no option to have the PC/Mac as a controller, which I don't fully understand why.
Another thing, the iPhone 15 Pro operates at 6ghz -- and the "controller" app here (Sonos) keeps having trouble seeing my systems when I leave the house and return -- just now, for example. But the app on my Macbook is operating the speakers and streaming just fine (I have a 16" Macbook Pro (Intel)). Right now, the iOS "controller" app says "Unable to find your Sonos system, let's fix it" LOL I'm like WTF for the Nth time of this....
I've reset this iOS app a few times, it's really frustrating -- that this doesn't work more smoothly.
The Sonos rep and I were trying to join the Gen 1 Playbar to just the 2.4ghz SSID, but we just didn't have any luck.
CrimpOn
Oct 20, 2023Guru - Experienced User
I fear there is too much fixation on frequency. For example:
While technically correct, this is not material. The iPhone 15 Pro has this specification:
From Apple:
https://support.apple.com/kb/SP903?locale=en_US
- Wi‑Fi 6E (802.11ax) with 2x2 MIMO9
From GSM Arena:
https://www.gsmarena.com/apple_iphone_15_pro-12557.php
a/b/g/n/ac/6e, means that it supports 2.4G and 5G WiFi (dual band) including every WiFi standard from the very first (802.11a) through the most recent (802.11ax) and also supports the new WiFi6E (6Ghz frequency band). This iPhone is supposed to communicate with any form of WiFi, from the oldest pre-2000 WiFi to the latest, which also is supported on the RBRE960 Orbi system. i.e. if you enable the WiFi6E (6GHz) feature on this Orbi system, the iPhone should connect to it.
(See page 62 of the user manual:
https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960_RBSE960_UM_EN.pdf )
The way the vast majority of Internet of Things (IoT) devices work is
- When it is waiting to be configured, the device (soundbar) broadcasts a WiFi signal with some goofy name (like maybe 'sonos-12345'.
- The app installed on the smartphone looks for a WiFi access point with that goofy name and connects to it.
- If the device is supposed to connect to the home WiFi (and nearly all of them do), the app communicates the WiFi credentials to the device, i.e. WiFi SSID and password.
- The device searches for a WiFi system with that SSID, asks to associate with it (fancy term for connect), supplies the required password, and is connected.
- From then on, if either the IoT device or the WiFi network is powered off, when power is restored the IoT device connects automatically.
- The smartphone can connect to the primary, IoT, or 6G network at any speed. Because they communicate through the network, there is no problem.
Some IoT devices have smartphone apps that are poorly written:
- Some of them detect that the smartphone is connected to WiFi at 5G and refuse to proceed. "MUST have 2.4G" they scream. Ironically, if they would just deliver the SSID/password to the IoT device, it would find the WiFi network just fine. But they are trying to be too helpful and will not proceed.
- Some of them appear to convey the hardware MAC address of the 5G WiFi access point to the IoT device. Having only a 2.4G radio, it cannot find this access point. Again, trying to be too helpful.
- Some are just s**t. (I won't name the brand, but...) It took me almost 10 tries to get a window blind controller to work. The setup failed over (and over, and over). Did everything but light a candle. Finally, success.
So, what's the solution? The most common tactic is to have the smartphone connected at 2.4G to the desired WiFi SSID. Complete the setup. After that, the smartphone can connect any way it pleases and everything will be good.
There are several ways to do this:
- Some users keep an old WiFi router (in a box or on a shelf) that can disable 5G. Temporarily power off the Orbi. Connect the old router and set it to exactly the SSID/password used by the Orbi. The smartphone will connect at 2.4G because that is all there is. After the setup, remove the old router and power on the Orbi.
- Some users create a 2.4G WiFi Hot Spot on one cell phone with exactly the same SSID/password as the Orbi. Power off the Orbi. Go through the setup. etc. etc.
- Some of the newer AX routers now offer an IoT SSID that can disable 5G (including the 960). Connect the smartphone to the 2.4G IoT SSID and go through the setup.
It would be really helpful to (a) have a link to the Sonos Soundbar setup instructions, and (b) have detailed information about exactly how the setup process fails.
- gumpgumpOct 21, 2023Guide
In the UI of the latest firmware, I should be able to disable 5ghz completely, reboot and have 2.4ghz. The Sonos rep and I worked through this and unfortunately it does not work. Our goal was to get the entire group of the Sonos speakers to connect to the IoT network and leave it at 2.4ghz-only. But no dice.
I also found the hidden web menu on Sonos devices and was able to get some info out of that; but didn't write it down. I wish there were a direct CLI tool to connect to these and manually tweak their configs, but that's another topic.
The Playbar Gen 1 is 2.4ghz only. No way around that. But it just refuses to join this network -- Sonos says, from their internal tools, that it's connected and I see the connection and IP on the Netgear interface, but it doesn't ping. Nmap doesn't show much, either.
Right now, the iOS app is completely f'ed up and doesn't have any of my devices shown, but the app on my Mac does. Another topic.
I tend to think the logic of the Sonos rep is solid; that is, getting these on the IoT network --- but I can't see that happening after so many attempts.
So I see a couple of issues. One, the Netgear Orbi should disable the 5ghz radio if I tell it to and reboot. It doesn't appear to. Second, the Playbar Gen 1 connects to the Orbi, gets an IP but doesn't ping -- makes me think it's not routing IP, but will route the Sonos protocol (which I believe is proprietary).
The next trick (GRIN) I can think of is these WIFI dongles -- that plug in to an ethernet port and connect via WIFI. The Playbar has two ethernet ports (I wonder why 2). Perhaps I could try that as a last ditch effort.
The setup guide for the Playbar:
https://www.sonos.com/pdfs/productguides/en-us/sonos-user-guide.pdfThank again!
I just thought of something. I could take a Raspberry Pi (I have a few) and load up one of those third-party router firmwares (OpenWRT, etc) and create the SSID IoT network there (BROADCOM), turning off my Netgear Orbi for the time. Then I could try to force all my Sonos devices onto that at 2.4ghz.
Just a thought. But like I mentioned, while working with Sonos support yesterday (who were very patient), we could not get the RBRE960 to disable the 5ghz radio.
The other idea is to buy an ethernet (direct) to WIFI adapter/dongle -- there are several that people use to re-purpose older equipment. As the Playbar Gen 1 has two ethernet ports, I could get this to potentially join the 5ghz network this way.
I wish the Netgear firmware allowed for CLI access and better fine-tuning -- still puzzled as to why I couldn't disable the 5ghz radio.
- CrimpOnOct 21, 2023Guru - Experienced User
This is correct. The actual 5G radio cannot be disabled. It is essential to provide the router to satellite backhaul link. (Even if there is a wired connection between the units, the 5G WiFi link remains available.) Broadcast of the primary SSID on both 2.4G and 5G cannot be disabled. (And the Guest SSID if Guest WiFi is enabled.) The 5G radio cannot be turned off.
What can be disabled is broadcasting the IoT network SSID on 5G. On page 65 of the User Manual:
If 2.4 GHz only is selected, then the IoT SSID will appear only at 2.4GHz. If the Sonos is told to connect to the IoT SSID, then the only radio it can access is the 2.4G radio.
