shunail
Dec 09, 2022Aspirant
RBRE960 and worst support for most expensive system
I've bought Orbi RBRE960 3 pack plus 2 more RBSE960 Satellite and apparently, for some reason, I've 2 rogue Satellite, which I tried app and web interface, but could not remove those rogue APs from...
Mikey94025
Dec 09, 2022Hero
Is this just a false display issue or is your Orbi network negatively impacted in some way? Do you see the same rogue (extra) satellites in orbilogin.com as well as the Orbi app?
I suspect that if you factory reset the Orbi (not just restart or delete) then you can make these go away. It's unfortunate and should not be necessary for you to do that, of course.
- shunailDec 09, 2022Aspirant
They're showing in both Orbi app and web interface (Orbi login portal for the router)
I guess I've to do a full factory reset on all and add them again. That'd be another 2 hours of my setting them up again
