workmangc
Sep 21, 2024Aspirant
RBRE960 Cannot disable guest network
Hello. I have a mesh system consisting of an RBRE960 router and 2 RBSE960 satellites. I've recently noticed that my guest network is always broadcasting even though I have disabled it. I am runn...
CrimpOn
Sep 21, 2024Guru - Experienced User
Do devices connect to the Guest WiFi and get internet access?
- workmangcSep 21, 2024Aspirant
I don't believe so. Let me try.
No. I cannot. On further checking, it appears that it may be one of the satellites that is broadcasting the ssid.
I don't see the network on my iphone until I go outside (satellite in the detached garage).
- CrimpOnSep 21, 2024Guru - Experienced User
If nothing will connect to Guest, then this might be one of those irritating things that no one can explain.
