workmangc
Sep 21, 2024Aspirant
RBRE960 Cannot disable guest network
Hello. I have a mesh system consisting of an RBRE960 router and 2 RBSE960 satellites. I've recently noticed that my guest network is always broadcasting even though I have disabled it. I am runn...
CrimpOn
Sep 21, 2024Guru - Experienced User
Do devices connect to the Guest WiFi and get internet access?
workmangc
I don't believe so. Let me try.
- workmangcSep 21, 2024Aspirant
No. I cannot. On further checking, it appears that it may be one of the satellites that is broadcasting the ssid.
I don't see the network on my iphone until I go outside (satellite in the detached garage).
- CrimpOnSep 21, 2024Guru - Experienced User
If nothing will connect to Guest, then this might be one of those irritating things that no one can explain.
- FURRYe38Sep 22, 2024Guru - Experienced User
Sounds like the garage RBS may not be getting a full sync thus not getting the condition set from the RBR for GN being disabled. Might bring the RBS in closer to the RBR and see if it will sync fully and not broadcast the GN.
