Pardman
Jul 28, 2022Tutor
RBRE960 Connected Devices Not Showing up in Active Device List
I have the following setup RBRE960 Router (V6.0.3.85_3.1.15 firmware) Three attached satellites (same firmware version) Number of Attached Devices: 91 Access Control = Off Issue: - I am ...
Jul 29, 2022Guru - Experienced User
2 things to check.
1. if you log into the satellite (using its ip address) that its connected to, does it show up under the attached devices list there?
2. Does it show under the access control panel? (doesn't have to be on)
