Pardman
Jul 28, 2022Tutor
RBRE960 Connected Devices Not Showing up in Active Device List
I have the following setup RBRE960 Router (V6.0.3.85_3.1.15 firmware) Three attached satellites (same firmware version) Number of Attached Devices: 91 Access Control = Off Issue: - I am ...
Mikey94025
Jul 29, 2022Hero
Pardman wrote:- This is an issue because I need to forward a port to the device, but believe I am not able to do so unless the device is list in the actual attached devices list of the router.
Fortunately you can port forward to any IP address. The device doesn't have to be in the list. In the Port Forwarding page of orbilogin.com, press "Add Custom Service" and type the internal IP address (instead of using the "Or select from currently attached devices" list shown below the IP address text boxes).
