Nobber1066's avatar
Nobber1066
RBRE960 DoS Attacks in log
Hello I have a BT SMART Hub set to bridging mode with my RBRE960 router and two satellites
I checked the logs to day and noticed this
Sample - lots more lines
[DoS attack: DoSPortScan] from source 77.90.185.157,port 58783 Tuesday, Aug 22,2023 22:37:11
[DoS attack: DoSPortScan] from source 148.113.16.231,port 58368 Tuesday, Aug 22,2023 22:36:49
[DoS attack: DoSPortScan] from source 77.90.185.150,port 57341 Tuesday, Aug 22,2023 22:36:46
[DoS attack: DoSPortScan] from source 179.43.191.194,port
Is this normal have I missed some security setup
Thank you
  • FURRYe38's avatar
    Just the logs reproting what the RBR is blocking.
    Do a whois look up on those WAN IP addresses to see where there coming from.
