Mechanic60's avatar
Mechanic60
RBRE960 Extra Satellite shows up when using wired backhaul both in web app and Orbi app
Hi, I just installed my brand-new RBRE 960 Orbi And two satellites. They are working fine but both in the web app and in the Orby app I am seeing an extra satellite with a different IP address and a...
  • Mechanic60's avatar
    Mechanic60
    Mar 29, 2022
    I tried Netgear gigabit Five port switch I have.  And the Issue went away.  So the trend net switch is the issue. Thanks for all your help. It’s too bad because I wanted to use the 2.5 Gb switch for the bandwidth because I will be getting a 2 Gb connection to the Internet very soon. I will have to find another solution for a switch. Again thank you for your help.
