CMoneyTrading
Nov 23, 2022Aspirant
RBRE960 Firmware upgrade unable to process
See pic. When I go to orbilogin.com and try to upgrade the firmware on the router, the site keeps checking for the satellites and never finishes. I've tried in Chrome and other browsers. So ...
Nov 24, 2022Guru - Experienced User
You can manually update.
I'd highly recommend updating the satellites first and then the router.
Try putting all the RBS in the same room as the RBR and try updating them one at a time. Turn them ON one at a time. Manually update the RBS using the RBS web page to send the FW file to the RBS.
