Pauly6String
Jul 02, 2022Tutor
RBRE960: I'm having same 400 Bad Request problem
Was it a factory reset or reboot? I'm having same 400 Bad Request problem.
- Jul 02, 2022
Make sure the device name doesn't contain any special characters like &
I noticed I had the same issue with one of my devices I was trying to reserve. Removing the special character fixed the 400 Bad Request problem.
NG could do a better effort here and print out a more descriptive error message than the generic "400 Bad Request".
codejanitor
Jul 02, 2022Star
Pauly6String
Jul 02, 2022Tutor
"Make sure the device name doesn't contain any special characters like &
NG could do a better effort here and print out a more descriptive error message than the generic "400 Bad Request"."
About ten seconds after I made my post I changed my router name from Orbi Wan (with space) to Orbi-Wan and that fixed it.
Thanks for the reply. Been a month trying to figure it out
- FURRYe38Jul 03, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- Pauly6StringJul 03, 2022Tutor
I have made a CONFIG file now that I have 95% of my devices using an assigned IP now. Orderly, ah!!
