vblack
May 18, 2022Star
RBRE960 Internet connection lost
Hi. I have experience very strange situation with my RBRE960 system. It is loosing internet connection almost every day, sometimes twice a day (no internet, red LED light). To restore connection all...
vblack
May 19, 2022Star
There is no modem. I have direct connection to ISP via twisted pair cable, in my case it is UTP 5e, on the ISP side it is probably media-converter to optic cable (it is usual in our area) Cat6 STP required to achieve stable 2.5G, but not necessary for 1G. I doubt it is a cable problem, rather Orbi has some strange reaction on something on network, probably a bug somewhere in protocols. Because it is require physical link re-initialization to resolve, but without Router reboot!
As CrimpOn suggested I trying to contact Netgear support, but this router was pre-owned, So I need to resolve a serial number registration issue first to do that. Then I will know is there something left from 90 days complimentary support.
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
CAT6 STP or CAT6A STP is recommended for the RBR.
vblack wrote:Hi.
I have experience very strange situation with my RBRE960 system. It is loosing internet connection almost every day, sometimes twice a day (no internet, red LED light). To restore connection all I have to do is unplug internet cable and plug it back. Same behavior I have with my previous RBR850, which I switched to new RBRE960 hoping that this annoying issue is gone, but it is not.
Surprisingly that my first Orbi SRR60 - does not have this issue, neither other company WiFi router - internet stable for weeks on exactly same setup (even same LAN cable).
My current setup:
RBRE960 FW V6.0.3.85_3.1.15
Internet connection - LAN (UTP5e cable from provider, no any auth, just DHCP)
I have tried everything - resetting router, change Internet parameters to static IP (just in case).
Is there any way to see what is going on, why internet connection is lost ? How to fix this ?
Thank you.
May 19, 2022Guru - Experienced User
Something to contact NG support for additional help and information.
Also brand and model of the ONT maybe helpful as well.
- vblackMay 20, 2022Star
So, I have registered my product. But unfortunately 90-days support has expired.
I have reproduced issue with debug on and collect a logs while issue is still there (No internet connection) and after I re-plug Ethernet cable (and Internet connection appeared).
Only option I have now is to by 6 month support for 90 USD ?
Of course I could try to use ugly workaround with buying some other (not NG) router to put it before and switch Orbi into AP, but this would be very bad solution for an $1.5K system...
- FURRYe38May 20, 2022Guru - Experienced User
Ok, I've passed this on to NG for review.
When did you buy this system?
